After completing a backup using the useful scripts from emoncms.org to local, When I go to the feeds view it will not load, the spinning wheel just spins, it looks like all details are correct, as I sync the dashboards down and I can see the dashboards I created and the data there, but I am unable to get the feeds page loaded.
and I am seeing these erorrs in the logs
2018-09-28 12:30:11.801|WARN|PHPFina.php|get_meta() meta file does not exist '/home/pi/data/phpfina/132275.meta' 2018-09-28 12:30:11.803|WARN|PHPFina.php|post_bulk_prepare() failed to fetch meta feedid=132275 2018-09-28 12:30:11.804|WARN|PHPFina.php|get_meta() meta file does not exist '/home/pi/data/phpfina/132275.meta' 2018-09-28 12:30:11.806|WARN|PHPFina.php|post_bulk_prepare() failed to fetch meta feedid=132275 2018-09-28 12:30:11.807|WARN|PHPFina.php|get_meta() meta file does not exist '/home/pi/data/phpfina/132275.meta' 2018-09-28 12:30:11.809|WARN|PHPFina.php|post_bulk_prepare() failed to fetch meta feedid=132275 2018-09-28 12:30:11.826|WARN|PHPFina.php|get_meta() meta file does not exist '/home/pi/data/phpfina/132278.meta' 2018-09-28 12:30:11.828|WARN|PHPFina.php|post_bulk_prepare() failed to fetch meta feedid=132278 2018-09-28 12:30:11.830|WARN|PHPFina.php|get_meta() meta file does not exist '/home/pi/data/phpfina/132278.meta' 2018-09-28 12:30:11.831|WARN|PHPFina.php|post_bulk_prepare() failed to fetch meta feedid=132278 2018-09-28 12:30:11.833|WARN|PHPFina.php|get_meta() meta file does not exist '/home/pi/data/phpfina/132278.meta' 2018-09-28 12:30:11.834|WARN|PHPFina.php|post_bulk_prepare() failed to fetch meta feedid=132278 2018-09-28 12:30:11.836|WARN|PHPFina.php|get_meta() meta file does not exist '/home/pi/data/phpfina/132278.meta' 2018-09-28 12:30:11.837|WARN|PHPFina.php|post_bulk_prepare() failed to fetch meta feedid=132278 2018-09-28 12:30:11.839|WARN|PHPFina.php|get_meta() meta file does not exist '/home/pi/data/phpfina/132278.meta' 2018-09-28 12:30:11.841|WARN|PHPFina.php|post_bulk_prepare() failed to fetch meta feedid=132278
