# Avoiding wireless connections - EmonTX serial RPiZero solution
**URL:** <https://community.openenergymonitor.org/t/avoiding-wireless-connections-emontx-serial-rpizero-solution/15056>\
**Category:** Hardware\
**Created:** [11 August 2020 19:49 UTC](https://community.openenergymonitor.org/t/avoiding-wireless-connections-emontx-serial-rpizero-solution/15056 "2020-08-11T19:49:12Z")\
**Showing post:** 35
**Author:** ![haffle](https://community.openenergymonitor.org/letter_avatar_proxy/v4/letter/h/d07c76/32.png) [@haffle](https://community.openenergymonitor.org/u/haffle)\
**Post date:** [27 August 2020 08:28 UTC](https://community.openenergymonitor.org/t/avoiding-wireless-connections-emontx-serial-rpizero-solution/15056/35 "2020-08-27T08:28:29Z")
Woo Hoo! Commenting out those two lines ( `arm_freq=1200` and `gpu_mem=16` ) & rebooting the Pi Zero, and it appears in the router’s CP.
After typing in the LAN IP I get the “Welcome to your emonPi” page. This is presumably what @lgheorghe was seeing on [Getting setup wizard page instead of login](https://community.openenergymonitor.org/t/getting-setup-wizard-page-instead-of-login/15205) . I clicked on the wifi option, and then after reconnecting to emonpi.local I get in to a bit of a loop - searching for networks (again).
Not sure how important this is - possibly related to the above - but above the Welcome page there is a warning message
` **Warning** : file_get_contents(/etc/wpa_supplicant/wpa_supplicant.conf): failed to open stream: Permission denied in **/var/www/emoncms/Modules/setup/setup_model.php** on line **24** `
The Pi is powered through my emonTx, with the wires connected as per @pb66 's second schematic:
4: 5v \> 5v
6: Gnd \> gnd
8: tx \> tx
10: rx \> rx
12: p12 \> rts
I am able to ssh in to the Pi, but my linux skills are so limited that I although I am able to use some _very_ basic commands (`cd` and `ls` etc), am not yet able to poke around (or change) anything. (EDITORS Note: Good job probably 😀 )
So, progress (thank you all), but still not quite there yet.
_[View the full topic](https://community.openenergymonitor.org/t/avoiding-wireless-connections-emontx-serial-rpizero-solution/15056)._
