kevin
(kevin)
4
Further reading, starting at the build guide has led me to this thread
https://openenergymonitor.org/emon/node/12566
and specifically this part
“The problem with the new firmware appears to be syntax related; “commit=120” on the line for the data volume in /etc/fstab is the issue. Reading from here: Ext2/Ext3 File System it looks like you are trying to use an EXT3 feature on an EXT2 filesystem, so removing the argument from /etc/fstab should have 0 effect (other than allowing the new 4.4 kernel to boot fully).”
which makes sense given that if I remove the commit line the thing boots again, and that is has gone from the version of FSTAB on GITHUB. Assuming I can get Samba to work again I have a working update which is way less work than rolling a new image.
I’ll now have another dig in case there is anything else that has changed between versions before I play with images again. From memory the image I made up from the build guide was pretty close to the released image which is why I didn’t change to it.
