I have the problem with Emoncms on my emonbase after playing around with the feeds and then it crashed. So I tried to reboot it again and it turns out like on the pic attached and on the feeds screen just keeps loading.
I installed emoncms on a Raspberry PI3. After installation I can login. After login I see a spinnig wheel. Nothing happens and my raspberry crashes. So it isn’t reachable. I have
to disconnect and reconnect the powersupply. So after the hard reset it works again till I try to login to emoncms.
Does somebody knows this problem? Do you need a log file? If yes, which one?
