Hello,
how to correct that kind of mistake?
Thanks for reporting this issue, it’s a known issue and is being worked on. For now just ignore the message.
I noticed you have selected divertmode_state
and ev_state
as the feeds to be graphed. I would not recommend using a App graph to view the divert state, this feed is best viewed using Graph viewer or a dashboard, ev_state
is not a kwh feed.
You want to select a power and energy feed. If you have followed the Emoncms OpenEVSE setup guide then you should have feeds called ev_power
and ev_energy
See github issue tracking this issue:
what is the function of ev_powere, ev_energy?
