I already have a Pi 3. I live in the US. I would like to build a emonPi with the case and everything for solar.
What all do I need to buy?
My solar already has its own monitor system, so I just need to monitor my home usage inside the house. Coming into my breaker box in the basement is a single large cable. See attached picture.
There are 4 cables coming out of the main cable. One looks like earth ground because it is bare wire.
The other 3 are black, black / red and black / white. The black and black / red both go into the center area of the breaker box. The black / white one only goes to one side of the panel where all the white wires from all the plugs in the house connect to.
With that information what can you tell me about hooking up the whole thing.
@Bill.Thomson will be able to advise you on placing your CTs, but it’s likely that the CT included WON’T fit on your cables. There’s a lot more in the “N.America” page and lists of suitable CTs.
Good eyeball calibration, Robert. His feeders look to be AWG 2/0 i.e. too large for the shop-sold CT.
Tony,
Other OEM users in the US have used Magnelab and Byram Labs CTs with good results.
One CT which we’re familiar with, and is known to work well with OEM is the Magnelab SCT-0750-000.
See the section titled EmonTx - Use in North America on this page for more info.
The black and black/red wire are the hot legs. The black/white wire is the neutral leg.
Use care while working inside your load center (breaker box) as the black and black/red wire are always live unless there is a disconnect upstream from the load center.
Is there a standard connector on that larger CT? It seems like it will only come with a twisted pair of wire.
Would it be safe to just chop off the connector that comes on the CT that will come in the package from you OpenEnergyMonitor when I buy the kit or do I need something larger?
Which cable in my breaker box should I connect the large CT to? Obviously it would be easiest to connect to one of those black cables going into either side of the breakers, but I want whole home usage and those look like they go to one side or the other…
Correct. It ships without a conector.
The connector you need is a standard 3.5mm (1/8th inch) stereo plug. Tip and sleeve are used, the ring is not conected. Here’s an example sans insulating shell:
Thank you for the answer. The package I will buy comes with the smaller CT. Can I just cut that connector off and solder the wires to the new one? Are they polarized or does it not matter which wire to which?
You could do that. But 1/8th inch stereo plugs are inexpensive, and one similar to that in the picture would make a “cleaner” installation.
They aren’t polarized in a DC sense, but you need to keep the phase relationship between the two correct. It’s explained on the “Use in North America” page I linked to above.
The latest YHDC CTs come with a moulded-on plug. If yours comes like that, cutting it off won’t help you. It’s a case of 2 new 3.5 mm plugs. If you do get the phase relationship wrong, it’s simply a case of flipping the CT on its cable, or if that’s hard, multiplying by -1 in the software somewhere.
Make a list of the electrical loads (appliances) you have. The large loads, like air conditioner, water heater, stove, oven, etc. If you have gas fired water/space heating, etc, you simply ignore the item.
Look at the nameplate on each item for the current draw. Add them up and you’ll have a rough estimate.
