I try to upload my backup data, it’s work correctly but something is strange.
strange thing:
the imported data was added on a “nogroup” list
new feed added automatically to “Node emonpi”
when i add the feed if i set the name as “use” it doesn’t work if I add the “use” at the end of proposed name it works!
it’s strange and no guide describe this particular situation.
here is the emoncms log
2017-01-01 16:06:19.329|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2017-01-01 16:06:24.333|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2017-01-01 16:06:29.332|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2017-01-01 16:06:34.334|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2017-01-01 16:06:39.344|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2017-01-01 16:07:10.667|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2017-01-01 16:07:10.914|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2017-01-01 16:07:15.685|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2017-01-01 16:07:20.684|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2017-01-01 16:07:23.455|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2017-01-01 18:15:03.612|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2017-01-01 18:23:16.902|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2017-01-01 18:23:38.356|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2017-01-01 18:23:38.533|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2017-01-01 18:23:42.430|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2017-01-01 18:36:34.590|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2017-01-01 18:39:18.596|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2017-01-01 18:39:18.797|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2017-01-01 18:39:23.349|ERROR|feed_model.php|EngineClass() Engine id '1' is not supported.
2017-01-01 18:46:01.359|WARN|phpmqtt_input.php|Starting MQTT Input script
2017-01-01 18:46:02.483|WARN|phpmqtt_input.php|Subscribing to: emon/#
2017-01-01 18:46:02.483|WARN|phpmqtt_input.php|Not connected, retrying connection
2017-01-01 18:46:02.484|WARN|phpmqtt_input.php|Connecting to MQTT server: Connection Accepted.: code: 0
2017-01-01 18:46:02.484|WARN|phpmqtt_input.php|Subscribed to topic: emon/#
2017-01-01 20:00:13.999|WARN|feed_model.php|Feed model: Requested feed does not exist feedid=0
thisi is the emon hub log
2017-01-01 20:36:24,792 INFO RFM2Pi Publishing: emonhub/rx/5/values 496,-8,488,216.82,0,0,0,0,0,0,0
2017-01-01 20:36:24,794 INFO RFM2Pi Publishing: emonhub/rx/5/rssi 0
2017-01-01 20:36:24,795 DEBUG RFM2Pi 1326 adding frame to buffer => [1483302984.770514, 5, 496, -8, 488, 216.82, 0, 0, 0, 0, 0, 0, 0]
2017-01-01 20:36:24,796 DEBUG RFM2Pi 1326 Sent to channel(end)' : ToEmonCMS
2017-01-01 20:36:25,707 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 29 101 212 36 76 16 216 130 145 227 110 148 143 101 39 223 157 53 159 56 126 (-99)
2017-01-01 20:36:29,752 DEBUG RFM2Pi 1327 NEW FRAME : OK 5 237 1 249 255 230 1 0 85 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 (-0)
2017-01-01 20:36:29,757 DEBUG RFM2Pi 1327 Timestamp : 1483302989.75
2017-01-01 20:36:29,758 DEBUG RFM2Pi 1327 From Node : 5
2017-01-01 20:36:29,758 DEBUG RFM2Pi 1327 Values : [493, -7, 486, 217.6, 0, 0, 0, 0, 0, 0, 0]
2017-01-01 20:36:29,759 DEBUG RFM2Pi 1327 Sent to channel(start)' : ToEmonCMS
2017-01-01 20:36:29,760 INFO RFM2Pi Publishing: emon/emonpi/power1 493
2017-01-01 20:36:29,763 INFO RFM2Pi Publishing: emon/emonpi/power2 -7
2017-01-01 20:36:29,765 INFO RFM2Pi Publishing: emon/emonpi/power1pluspower2 486
2017-01-01 20:36:29,767 INFO RFM2Pi Publishing: emon/emonpi/vrms 217.6
2017-01-01 20:36:29,768 INFO RFM2Pi Publishing: emon/emonpi/t1 0
2017-01-01 20:36:29,770 INFO RFM2Pi Publishing: emon/emonpi/t2 0
2017-01-01 20:36:29,772 INFO RFM2Pi Publishing: emon/emonpi/t3 0
2017-01-01 20:36:29,774 INFO RFM2Pi Publishing: emon/emonpi/t4 0
2017-01-01 20:36:29,776 INFO RFM2Pi Publishing: emon/emonpi/t5 0
2017-01-01 20:36:29,777 INFO RFM2Pi Publishing: emon/emonpi/t6 0
2017-01-01 20:36:29,779 INFO RFM2Pi Publishing: emon/emonpi/pulsecount 0
2017-01-01 20:36:29,782 INFO RFM2Pi Publishing: emon/emonpi/rssi 0
2017-01-01 20:36:29,784 INFO RFM2Pi Publishing: emonhub/rx/5/values 493,-7,486,217.6,0,0,0,0,0,0,0
2017-01-01 20:36:29,786 INFO RFM2Pi Publishing: emonhub/rx/5/rssi 0
2017-01-01 20:36:29,788 DEBUG RFM2Pi 1327 adding frame to buffer => [1483302989.752264, 5, 493, -7, 486, 217.6, 0, 0, 0, 0, 0, 0, 0]
2017-01-01 20:36:29,789 DEBUG RFM2Pi 1327 Sent to channel(end)' : ToEmonCMS
2017-01-01 20:36:29,996 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 31 146 189 96 54 59 144 31 195 184 244 247 183 166 61 225 29 224 218 115 158 (-101)
2017-01-01 20:36:32,186 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 13 254 242 239 185 19 3 23 122 95 85 33 250 131 211 243 96 66 95 183 74 (-102)
2017-01-01 20:36:32,410 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 31 251 91 215 229 29 189 241 180 204 23 225 104 144 105 180 60 139 75 79 13 (-94)
2017-01-01 20:36:33,669 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 2 174 237 5 73 252 113 71 240 250 63 212 144 9 92 156 140 178 56 76 134 (-96)
thanks for the help given
If it is not only my problem, it have to be clarify end indicate somewhere in the guide.
Thanks again.
I’m obviously available for test on my particular situation.
