All my feeds stopped recording data on emoncms.org
Hi Everybody,
Since several days I am posting up time (and couple of other variables) of ESP8266 modules on emoncms.org as shown below:
About 2016-06-23 22:32:00, basing on what I see in the Data viewer, all my feeds stopped recording data:
On the other hand I still see changes in the Feeds, column Updated: like “14s ago”, etc:
If I create a new feed, post couple of samples and open it in the Data viewer, then I see dozens of lines with the following error:
Request error Warning: unpack(): Type x: not enough input, need 1, have 0 in /var/www/emoncms/Modules/feed/engine/PHPTimeSeries.php on line 347 Warning: unpack(): Type x: not enough input, need 1, have 0 in /var/www/emoncms/Modules/feed/engine/PHPTimeSeries.php on line 347 Warning: unpack(): Type x: not enough input, need 1, have 0 in /var/www/emoncms/Modules/feed/engine/PHPTimeSeries.php on line 347 Warning: unpack(): Type x: not enough input, need 1, have 0 in /var/www/emoncms/Modules/feed/engine/PHPTimeSeries.php on line 347 Warning: unpack(): Type x: not enough input, need 1, have 0 in /var/www/emoncms/Modules/feed/engine/PHPTimeSeries.php on line 347 Warning: unpack(): Type x: not enough input, need 1, have 0 in /var/www/emoncms/Modules/feed/engine/PHPTimeSeries.php on line 347 Warning: unpack(): Type x: not enough input, need 1, have 0 in /var/www/emoncms/Modules/feed/engine/PHPTimeSeries.php on line 347 Warning: unpack():
followed by:
on line 181 Warning: Cannot modify header information - headers already sent by (output started at /var/www/emoncms/Modules/feed/engine/PHPTimeSeries.php:347) in /var/www/emoncms/index.php on line 227 [[1466142300000,null],[1466143200000,null],[1466144100000,null],[1466145000000,null],[1466145900000,null],[1466146800000,null],[1466147700000,null],[1466148600000,null],[1466149500000,null],[1466150400000,null],[1466151300000,null],[1466152200000,null],[1466153100000,null],
What could be the cause of this issue?
Did I hit some data storage limit or I am posting too often?
Krzysztof
I’ve adjusted your account. You should be able to upload your images now.
Moderator, BT
OK, thanks for upgrading my account.
I have updated missing images.
Krzysztof
emoncms.org has a posting limit of 10s interval.
I have five ESP8266 modules and each is posting independently once per minute.
Posting time is not synchronized and they may end up posting at similar / the same time instead of every 12s sharp.
May this be the issue?
Should be fine. Would you mind PM’ing me your emoncms.org username. Would you mind if I took a look at your accont?
Glyn,
Thank you for support with this issue!
PM sent.
Krzysztof
The error was due to an issue with emoncms.org server, this should now be fixed by @TrystanLea. Please confirm
Hi Glyn and Trystan,
Starting on 2016-06-24 19:30:00 all my feeds are recording the data again:
Thanks a lot for resolving this issue!
Krzysztof
Hello
I have the same problem , my emoncms.org acount isnt working , the feeds arent taking new values since 24.07.2016, can someone help me with that ? , thanks
Carlos
Apologies there has been an issue on emoncms.org for a day or so on one of the servers affecting a limited number of feeds. This has been solved now. Please confirm.
Sorry for the inconvenience
Hello Glyn
Thanks for your reply, in my emoncms.org isnt solved the problem, the Link
to my emoncms Account is http://emoncms.org/Meusburger&id=31358, but i see
that now is working many thanks :slight_smile:
Carlos
2016-07-27 15:03 GMT+02:00 Glyn Hudson <
[email protected]>:
Hello Glyn
Since about 2 hours, my feeds are not updated at all. Could you please take a look?
Thanks in advance
Daturach
What is your emoncms username? Are your feeds still updating on your emonPi / emonBase? What does emonhub.log show on the emonPi?
Hello Glyn
Thanks for your quick answer.
Since around Midnight, everything is back to normal.
To answer your questions:
username: daturach
logfile was recording the data on my Raspberry and it looked as the data
was sent to emoncms.org. I can confirm this because I have 2 other
instances that were correctly receiving the data, one is Thingspeak and
the other is a emoncms.org cloud instance on a shared server.
I still have an “archaic” system; emontx with RFM12B (433 MHz) and
Raspberry with RFM69Pi. :slight_smile:
Thanks again
daturach
Great. Nothing wrong with that, I still have one of those systems in my house also :slight_smile:
