myozone
(Dave)
1
Hello, Just noticed the Emoncms Agile app isn’t reflecting the true price of Agile. It’s capped at 35 pence rather than higher. This is on a self hosted Docker install.
TrystanLea
(Trystan Lea)
2
Hello @myozone sounds like you need to select one of the other Agile tariff variants?
myozone
(Dave)
3
Thanks Trystan, I think I’m on an older version (I assumed Docker Watchtower would update it)
Dave
myozone
(Dave)
4
I’m on versions: Components
Emoncms Core v11.2.9 | App v2.6.8 | Dashboard v2.3.3 | Device v2.2.2 | Graph v2.2.3
And appears not to have been updated in a while, maybe an update could be pushed out?. The db was updated though
@glyn.hudson Could the Docker hub be updated please ?
TrystanLea
(Trystan Lea)
5
Hello @myozone would you be able to try @alexandrecuer docker container https://hub.docker.com/repository/docker/alexjunk/emoncms/
We really need to discontinue ours and switch over to Alex’s as the main one…
myozone
(Dave)
6
Hi Trystan, I hadn’t realised the Alex’s version was now the the go-to. Is there an easy way to import everything from the old version ?
Im not sure, perhaps the sync module could be used which is available on @alexandrecuer latest version? How are you posting data to the current docker container?
myozone
(Dave)
8
I’m using Node-red using the Emoncms node. I think probably it’s a manual job with new data.
Are you using the HTTP or MQTT api?
myozone
(Dave)
10
HTTP via an MQTT source (ESP32 counting flashes)
if you can copy over the mysql database and /var/opt/emoncms data files that should also work…
myozone
(Dave)
12
That worked, well until I messed it up somehow
Probably fumbled copy and paste to the wrong location - oh well good to start fresh with a new version. I still have the original version and may have another go when I get the time.
Thanks anyway.
Actually, the docker container expects a /data folder at the root of the host machine with an emoncms folder inside :
