On my empnPi running Nov’16 firmare, I’d already one temperature sensor connected at the emonpi RJ45 working fine and getting the readings as “t1”.
Now I’m trying to add additional DS18B20 temperature sensors plugged at the one-wire RJ45 interface.
I’m wiring them at the pins 2 (Vcc), 3 (GND) and 4 (data) of the RJ45 connector of the emonPi.
However, once connected, I’m not getting reading as additional temperature sensors (t2, t3 …) but as pulsecount…
At the log:
2017-04-29 12:12:21,309 DEBUG RFM2Pi 595 From Node : 5
2017-04-29 12:12:21,310 DEBUG RFM2Pi 595 Values : [1729, 775, 2504, 227.31, 16.8, 0, 0, 0, 0, 0, 1354]
2017-04-29 12:12:21,311 DEBUG RFM2Pi 595 Sent to channel(start)' : ToEmonCMS
2017-04-29 12:12:21,312 INFO RFM2Pi Publishing: emon/emonpi/power1 1729
2017-04-29 12:12:21,315 INFO RFM2Pi Publishing: emon/emonpi/power2 775
2017-04-29 12:12:21,317 INFO RFM2Pi Publishing: emon/emonpi/power1pluspower2 2504
2017-04-29 12:12:21,319 INFO RFM2Pi Publishing: emon/emonpi/vrms 227.31
2017-04-29 12:12:21,321 INFO RFM2Pi Publishing: emon/emonpi/t1 16.8
2017-04-29 12:12:21,324 INFO RFM2Pi Publishing: emon/emonpi/t2 0
2017-04-29 12:12:21,325 INFO RFM2Pi Publishing: emon/emonpi/t3 0
2017-04-29 12:12:21,327 INFO RFM2Pi Publishing: emon/emonpi/t4 0
2017-04-29 12:12:21,329 INFO RFM2Pi Publishing: emon/emonpi/t5 0
2017-04-29 12:12:21,330 INFO RFM2Pi Publishing: emon/emonpi/t6 0
2017-04-29 12:12:21,332 INFO RFM2Pi Publishing: emon/emonpi/pulsecount 1354
2017-04-29 12:12:21,334 INFO RFM2Pi Publishing: emon/emonpi/rssi 0
2017-04-29 12:12:21,336 INFO RFM2Pi Publishing: emonhub/rx/5/values 1729,775,2504,227.31,16.8,0,0,0,0,0,1354
2017-04-29 12:12:21,337 INFO RFM2Pi Publishing: emonhub/rx/5/rssi 0
I double checked the wiring, but looks fine. what else could I check?
