Hi . NOOB Alert
I have the latest software. I have an emonpi and am monitoring two CT clamps. CT 1 is on the Distribution board input.
CT 2 is in the solar output. I also have a separate meter for my car charger and have attached a pulse reader to it. The feed to the car charger is separate from the distribution board. So I thought I could get the Emonpi to add the car charger pulse output to the distribution board CT clamp output. I am sure the problem is me not understanding how it works.
The pulse reader (Car Charger) is set up as follows
1 Log to feed
2 x (X1)
3 Power to kWh
4Wh Accumulator
CT 1 is set up as
1 + input Node emonpi:pulsecount Car Charger
2 Log to feed Node emonpi: Use
3 - input Node emonpi:power2 Solar Feed
4 Power to kWh Node emonpi: Use_Kwh
5 Allow positive
6 Log to feed Node emonpi: Import
7 Wh Accumulator Node emonpi: Use
CT 2 is set up as
1 Log to feed Node emonpi: Solar
2 Power to kWh Node emonpi: Solar_Kwh
3 Wh Accumulator Node emonpi: Solar
This is my display
The Use reading stays the same even if I remove the pulse reader from the meter.
