So, new EmonTX with ID 7 added, and it shows as EmonTX 4 as expected, but I do not see any inputs, just RSSI:
My EmonPi is up to date, and emonCM configuration has the expected entries present for all inputs:
[[7]]
nodename = emontx4
[[[rx]]]
units =W,W,W,W,V,C,C,C,C,C,C,p
[[8]]
nodename = emontx3
[[[rx]]]
Not sure if I need to do something else to get the new inputs showing, I did a search but I can’t see anyone else having this issue most are about changing node ID etc - but I am just running two EmonTX v3 with the dip switch on the new one for Node 7.
