Welcome, Ashley, to the OEM forum.
There are so many points to answer, please forgive me if I miss one or two.
Are you looking to buy āfinishedā units, or would you be prepared to build something? The reason I mention that is thereās project that heavily borrows from OEM which uses a high-powered Arduino and a āDIYā front end for the analogue conditioning circuitry. Itās Home Energy Monitoring System
It has many more channels than an emonTx, but I doubt it can successfully run ācontinuous monitoringā as the emonTx does.
With our standard split-core YHDC c.tās, there is a tiny amount of crosstalk. I have never tested ring-core ones, but Iād certainly expect it to not be worse.
With so many c.tās in a normal C.U, you must go for the smallest ring-core one that will do the job. And yes, those RS ones will be suitable.
An emonPi is a Raspberry Pi with a two-channel emonTx attached, in a nice aluminium case with a LCD display. An emonBase is a Raspberry Pi with a radio attached, but no facility for voltage or current monitoring, no case, no display. And one you might not have spotted, A Raspberry Pi Shield is a Raspberry Pi with only the two-channel emonTx attached, nothing else.
The only difference is the value of the burden resistor. If you add a second burden resistor in parallel with the fitted SMD one - there are holes ready - you can make it what you like above that. As your biggest ring-core c.t. is likely to be 50 A and all require a 33Ī© burden, Iād advise removing all the fitted SMD burden resistors and replacing them with 1% (or better) 33 Ī© wire-ended ones - except probably for 1 channel for the main incomer.
In that respect, the emonPi and emonBase are identical. Connection is by 433 MHz ISM band radio.
Now this is where it gets tricky.
If you want 11 inputs, thereās no advantage in having an emonPi. 3 Ć emonTx will give you 12, plus an emonBase on which to run emonCMS should do what you need.
Normally, you can power a single emonTx from the a.c. adapter which is also its voltage reference for accurately measuring real power. Current is strictly limited because of the dent it makes in the waveform itās trying to measure. In your case, the most economical will be to power the emonBase and the emonTxās with a good clean 5 V d.c., and provide the a.c. voltage reference to all 3 from a single a.c. adapter. (You might want to consider a separate 5 V d.c. for the emonBase, because of noise considerations.) Provided you observe polarity (because one side of the a.c. input is grounded to a.c.), that will be fine as thereās almost no current drawn.
The downside to running 3 emonTxās into one emonBase (and thereās no solution to this) is they all use the same radio channel, so you might get two jamming each other on occasions.
A handful of 3.5 mm plugs to solder on the c.t. leads, d.c. plugs for the a.c. reference, and USB for the 5 V d.c.?
I am unable to speak for that system. The designer is a programmer by profession, living and working in the USA. Heās not an electrical engineer. The last time I checked, the claimed accuracy for the system overall was better than the accuracy tolerance of the input device. There are very few of us here who have any knowledge of iotawatt, it has its own support forum.
