# A question over whether emonCMS is compatible with MQTT
**URL:** <https://community.openenergymonitor.org/t/a-question-over-whether-emoncms-is-compatible-with-mqtt/7180>\
**Category:** Emoncms\
**Created:** [15 April 2018 18:24 UTC](https://community.openenergymonitor.org/t/a-question-over-whether-emoncms-is-compatible-with-mqtt/7180 "2018-04-15T18:24:47Z")\
**Showing post:** 5
**Post date:** [15 April 2018 23:09 UTC](https://community.openenergymonitor.org/t/a-question-over-whether-emoncms-is-compatible-with-mqtt/7180/5 "2018-04-15T23:09:12Z")
> [@stephen](#):
> why would they implement that when all you need to do is send the timestamp within the payload
To put the timestamp in the payload is a proper implementation. Currently emoncms is set up to receive mqtt data as a single raw value in a dedicated topic, there is no place for a timestamp.
There has already been discussions on this (in the [EmonHub Development](https://community.openenergymonitor.org/t/emonhub-development/6432) thread) and hopefully, there will soon be a more resilient method of posting mqtt data to emoncms. It has been recognized that there is significant difference in “broadcasting” the current value/status for everything as a separate topic for systems to be linked into and passing time specific data for the purpose of keeping records and accurately “monitoring” energy and environmental data.
The MAC id idea is fairly good, but for me it wouldn’t work as I try to have a “test” emoncms running to pull in changes and updates to, before pulling them in to the live instance.
Most energy data is collected at 10s intervals and every datapoint is valuable, I do not subscribe to the idea that if we have an abundance of data we can afford to be wasteful. I would like to get as complete a picture as possible without any missing data, that is easily done with buffering and confirmed delivery. If I was sending so much data that some was getting lost, that tells me I need to slow things down, if the data isn’t impotant enough to want to receive every datapoint, why send it?
The reason QoS 2 should be used is that (for example) updating and upgrading, when apache or emoncms or mysql needs updating, the mqtt broker should queue the data and pass it when the emoncms instance comes up, likewise when the MQTT broker needs updating, emonhub will (one day) buffer the data until mosquitto comes back on line. emonhub can be updated whilst it is running, it only needs restarting once the update is done, if the broker is online, there will be no buffered data to loose and only the few seconds it takes emonhub to restart will be missing data. This also applies to network outages etc, following a power cut, everything powers up, but the router can be somewhat slower, so buffering data is a good solution if all your servers are not on one device.
_[View the full topic](https://community.openenergymonitor.org/t/a-question-over-whether-emoncms-is-compatible-with-mqtt/7180)._
