However all the data appears to actually be there with data points every 10 seconds. As far as I’m aware, I setup the feeds as per the standard instructions. This casues issues when looking at the graphs on the ‘My Solar’ app.
Hello @markb this looks like the result of a mismatch between the interval that the data is posted to emoncms and the interval at which the data is saved to the feed. If you click on ‘Show options’ and put a tick in the averaging box you should see all of the missing data points disappear.
As this is on emoncms.org I can take a look at the account if you wish and see if it’s possible to fix.
Thanks Trystan, that does the trick for individual graphs. Maybe it’s a different issue, but this is what I see in the My Solar app (notice the solar flat sections):
