The EmonTX will do that with the appropriate sketch loaded. @Robert.Wall is better placed to advise.
There are a number of options to get the data from the EmonTX to an install of emoncms. Emoncms, whilst largely RPi based, can be run on any Linux environment (personally I run it in a ProxmoxVE container). You can transfer the data via the inbuilt RFM but, my suggestion would be to use Wi-Fi via either the EmonESP (simpler, available from the shop), or serial link an RPiZW to each EmonTX (more flexible and from experience more reliable).
HTH
