Im runing 2 versions in 2 sub folders
10.1.5 and 10.1.6
on the 10.1.6 all the inputs show as NULL
if you look at the graph all the dat is there hapily enough.
if you log into 10.1.5 everything is showing as updating perfectly.
this is installed via a fresh git pull using settings.ini
if i copy my old setings file over the same isue persists.
i have also noticed if you click on the feed process it does not take you to the feed in the graph
Server Information
Server Information
Services
- feedwriter :- Active Running - sleep 600s loading…
- redis-server :- Active Running
Emoncms
- Version :- 10.1.6
- Modules :- Administration | Dashboard v2.0.4 | Device v2.0.1 | EventProcesses | Feed | Graph v2.0.4 | Group v2.0.0 | Input | CoreProcess | Schedule | Time | User | Visualisation
Git :-
- URL :- GitHub - emoncms/emoncms: Web-app for processing, logging and visualising energy, temperature and other environmental data
- Branch :- * master
- Describe :- 10.1.6-119-g70e4be97
Server
- OS :- Linux 4.9.0-8-amd64
- Host :- vps640695 | vps640695.ovh.net | (51.38.69.188)
- Date :- 2019-09-27 18:21:18 BST
- Uptime :- 18:21:18 up 240 days, 7:11, 1 user, load average: 1.28, 0.69, 0.49
Memory
RAM :- Used: 15.07%
- Total :- 7.62 GB
- Used :- 1.15 GB
- Free :- 6.47 GB
Disk
/ :- Used: 12.97%
- Total :- 78.74 GB
- Used :- 10.21 GB
- Free :- 65.3 GB
HTTP
- Server :- Apache/2.4.25 (Debian) HTTP/1.1 CGI/1.1 80
MySQL
- Version :- 5.5.5-10.1.37-MariaDB-0+deb9u1
- Host :- localhost:6379 (127.0.0.1)
- Date :- 2019-09-27 18:21:18 (UTC 01:00)
- Stats :- Uptime: 20761865 Threads: 1 Questions: 245962902 Slow queries: 0 Opens: 420 Flush tables: 1 Open tables: 65 Queries per second avg: 11.846
Redis
- Version :- 3.2.6
- Size :- 9714 keys (2.86M)
- Uptime :- 240 days
PHP
- Version :- 7.0.33-0+deb9u1 (Zend Version 3.0.0)
- Modules :- apache2handler | calendar v7.0.33-0+deb9u1 | Core v7.0.33-0+deb9u1 | ctype v7.0.33-0+deb9u1 | curl v7.0.33-0+deb9u1 | date v7.0.33-0+deb9u1 | dom v20031129 | exif v7.0.33-0+deb9u1 | fileinfo v1.0.5 | filter v7.0.33-0+deb9u1 | ftp v7.0.33-0+deb9u1 | gettext v7.0.33-0+deb9u1 | hash v1.0 | iconv v7.0.33-0+deb9u1 | json v1.4.0 | libxml v7.0.33-0+deb9u1 | mbstring v7.0.33-0+deb9u1 | mcrypt v7.0.33-0+deb9u1 | mysqli v7.0.33-0+deb9u1 | mysqlnd vmysqlnd 5.0.12-dev - 20150407 - $Id: b5c5906d452ec590732a93b051f3827e02749b83 $ | openssl v7.0.33-0+deb9u1 | pcre v7.0.33-0+deb9u1 | PDO v7.0.33-0+deb9u1 | pdo_mysql v7.0.33-0+deb9u1 | Phar v2.0.2 | posix v7.0.33-0+deb9u1 | readline v7.0.33-0+deb9u1 | redis v4.2.0 | Reflection v7.0.33-0+deb9u1 | session v7.0.33-0+deb9u1 | shmop v7.0.33-0+deb9u1 | SimpleXML v7.0.33-0+deb9u1 | sockets v7.0.33-0+deb9u1 | SPL v7.0.33-0+deb9u1 | standard v7.0.33-0+deb9u1 | sysvmsg v7.0.33-0+deb9u1 | sysvsem v7.0.33-0+deb9u1 | sysvshm v7.0.33-0+deb9u1 | tokenizer v7.0.33-0+deb9u1 | wddx v7.0.33-0+deb9u1 | xml v7.0.33-0+deb9u1 | xmlreader v7.0.33-0+deb9u1 | xmlwriter v7.0.33-0+deb9u1 | xsl v7.0.33-0+deb9u1 | Zend OPcache v7.0.33-0+deb9u1 | zlib v7.0.33-0+deb9u1
